Pipe centerline
Pipe centerline
How do you switch off the centerline in a pipe? I've tried drawing config, enviroments and layers, nothing seems to work, not even blaking in the drawing
RE: Pipe centerline
pipe_solid_centerline NO, this will remove it from the modeling window.
In a drawing set hlr_for_pip_solid_cl YES , this will remove it from the drawing. Otherwise you would have to layer it off
