Line weight in drafting
Does any one have any idea about changing the line weight in drafting?
RE: Line weight in drafting
Do you want to change an individual line (select the line and you should see options in the ribbon at top of screen) or permanently change all the lines of a line style (format, style, select line in the top left box and away you go)?
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
In SE ST2 in the view tab click on styles and there you have a pulldown menu where you can select line and then you can edit the width of each line type.
If you have V20 or below look for the menu format if I remember right.
Hope it helps.
Patrick
