Concrete Air Entrainment in Painted Walls
Do tilt-up concrete wall panels that will be painted require air entrainment? I do not think they should but have not been able to find any information to back this up.
RE: Concrete Air Entrainment in Painted Walls
The only real problem that I have encountered with air entraining is when the owner wanted the inside face of the panel to have a smooth trowled finish. In these case, I have seen severe blistering. If the inside face is to receive a broom or similiar finish, the air will not be detrimental.
