Stormwater Quality Calculations
I am working with a few clients to develop a Stormwater Retrofit Plan. We are trying to reduce phosphorous being discharged in a TMDL watershed. One of the Retrofits being considered is the repair/rebuilding of roadside swales. The problem is estimating the current phosphorous contribution from the swales. A formula has been proposed to make this estimate. However, the source of the formula is not known. I was wondering if anyone has any information on the background of the formula. This is a copy of the formula:
"The following calculations will be used to determine the amount of Phosphorous that is reduced at each site. This calculation will be completed during the planning and design process to determine the current amount of Phosphorous. The calculation will need to be completed before implementation as well as after in order to find the change in Phosphorous levels. These calculations were developed by Westchester County and were approved for use by New York State Department of Environmental Conservation.
Pload = (0.4536) ((R-1)(A)(L)(BD)(Ptest))/((RP)(1,000,000))
where:
Pload = TP Loading (kg/yr)
R = enlargement ratio based on watershed impervious cover
A = existing channel area (SQFT)
L = channel or stream length(FT)
BD = bulk density (LB/CF)
Ptest = phosphorus level in soil (mg/kg)
RP = relaxation period (years)
0.4536 and 1,000,000 are conversion factors
A and L are to be based on field survey
BD will be assumed to be 95 LB/CF based on typ soil conditions
RP is set at an assumed value of 67 years, based on channel enlargement theory
R is based on site impervious cover and channel enlargement empirical data
Ptest will use standard published values (recommend using 300 mg/kg)
R as a function of impervious cover is empirically derived to be:
y = 0.0012(x)(x) + 0.0239(x) + 1
where y is enlargement ratio, x is imperviousness (%)"
Any information on the source of this formula would be useful.
where:
