Foundation settlement in layered soil
I am working on a foundation project were I need to compute the predicted settlements.
My soil profile is composed of 10' of Sandy silt (MLS), 20 of Silty sand (SM), 15 of silty gravel (GM) and another 15' layer of MLS.
I don;t have much of experience dealing with foundation settlements but I know there are bunch of methods available for computing elastic settlements. At least the most common I have seen are Theory of Elasticity and Schmertmann's method. To my knowledge Schmertmann's method is better than Theory of Elasticity because it takes into account several Elasticity Modulus values for layered soils, such as my case.
For the ones who like to compute settlements using the Theory of Elasticity, I have seen few examples were it is required to compute settlements for several layers and I have noticed the same formula (S = q * B * (1-u2)/E) is applied for each layer. What I noticed is those authors don't take into account the change (decrease) of stress (instead they used q), using boussinesq's chart, as the soil profile goes deeper.
Also I am not sure if the same footing width "B" I am supposed to keep it when analysing each layer. Probably the deeper the soil profile is, some reduction factor of the Base should be taken into account.
Can anyone give me some imput about this?
On the other hand, can anyone let me know what are the limitations of Schmertmann's method?, Or is this one simply the ideal for solving multilayered profiles?
Thanks a lot.
Thanks a lot.
RE: Foundation settlement in layered soil
In the absence of stress increase, there is no settlement (duh?). If there is stress increase, there will be settlement, based on the soil's elastic modulus. So, plot your change in stress with depth (i.e., using Bousinesq or Westegaard) and overlay your soil layers onto this stress envelope. (You may have to make soil sublayers in the upper interval to account for rapidly attenuating stresses.)
Let's say you have a sublayer that's 5 ft thick and the stress increase at the top is 1,000 psf and the stress increase at the base is 600 psf. Let's say the soil modulus is 100 tsf. If you integrate the stress profile with respect to depth, you'd have [(1,000+600)/2]*5=4,000 #/ft. If you divide that by the soil modulus you'd have:
(4,000 #/ft)/(100*2,000)=0.02 ft (1/4 in)
Do this for each layer.
Multiply by 1.2 for long term "creep" affects.
This is essentially the approach of Schmertman, just more fundamental. My university professor (J.M. Duncan) liked my solution to these problems, so it's not like I'm on some "flyer."
Enjoy!
f-d
¡papá gordo ain't no madre flaca!
I will try your way to see how it goes.
For your elasticity modulus values, which values you use?, the ones based on the SPT - N value or the standard values that are in the geotechnical books (which by the way, from book to book they are far away).
Do you think theory of elasticity formula is not applicable for this (S = q * B * (1-u2)/E), or better said, it would be applicable for one soil layer?
Thanks a lot again
hard to further help from here.
f-d
Schmertmann had a lot of experience in exactly these types of soils (much of his research was in Florida coastal plains soils of this type), so his data are relatively good. Schmertmann was a bit more theoretical than practical though, so if your soil is highly stratified (relative to the depth of influence of the foundation), be a bit careful with his method.
for stresses imposed in different layers of differing moduli values, the higher modulus value layers will "attract" more stress than the lower modulus value layers. There are several ways to determine the stresses with depth - use layered charts (see Poulos and Davis' "Elastic Solutions for Soil and Rock Mechanics").
Another way is to "increase" the layer thickness of the higher modulus values so that you have a uniform layer of the same value (Ron knows this from pavement design methods). Then you can compute the settlements from that - using chart or using elastic equations. One such method is Palmer and Barber (1940). They replace the upper layer thickness h having the elastic parameters E1 and mu1 by an equvialent thickness heq having elastic parameters of the lower layer material E2 and mu2 by:
heq = third root of (E1(1-mu2squared)) divided by (E2(1-mu1squared))
for those in India, Shenbaga Kaniraj's book "Design Aids in Soil Mechanics and Foundation Engineering" has very good and very detailed discussions of elastic theory and presents nearly all the charts found in Poulos and Davis - sometimes a bit clearer.
f-d
Have you ever tried to compute settlements using Burland and Burbidge's method (1984): "Settlement of foundations on sand and gravel, Proceedings of the Institution of Civil Engineers, Part 1, 1985, 78, Dec., 1325-1381."
It deals with the SPT-N value and depth of influence Zi, in which Zi = B^0.75.
I tried to compare values between your way (similar to Schmertmann's) and Burland and Burbidge's and with the last one I get very very low settlement values.
Using your way I get values of around 5 and 6 centimeters, whereas using Burland's and Burbidge's is get values of around 3 and 4 milimeters. Sorry for using SI units.
Do you know if Burland's and Burbidge's is well accepted in the geotechnical engineering industry?
Please let me know,
Thanks in advance
Sorry. . .
f-d
It sure is accepted, depending on local experience and engineers' habits though.
The difference in output you cite is not acceptable, there must be some mistake in one procedure or the other, i hope not in both of'em!!!
One improvement to B&B's method has been proposed by Berardi And Lancellotta of the Italian geotech school:
BERARDI R; LANCELLOTTA R., Stiffness of granular soils from field performance., GEOTECHNIQUE, pp. 149-157, 1991, Vol. 1, ISSN: 0016-8505
The method becomes more complex though and iterative techniques must be applied.
Thanks for your help.
Not many people I have spoken with know about B&B's approach.
Yeah, checked several times and using B&B's I am still getting too low settlement values.
So far, to me, using Schmmertmann's method is more realistic.
I will go through BERARDI R; LANCELLOTTA R and will see how more realistic would be B&B's approach.
might it be that in BB there is some conversion problem due to the bilog-scale axes in the N-Ic plot?
What's your average NSPT in the influence thickness?
The B&B´s approach I am using is the one I got from "Soil Mechanics in Practice Engineering" by Terzagui, Peck and Mesri (p. 396):
Sc = (1/3) * B^0.75 * (1.7/N60) * q
Where B is in meters and N60 is the average of SPT-N values measured within a thickness Zi (Zi = B^0.75). q is in Kpa and Sc in milimeters.
I am not sure what you mean by the N-Ic plot.
My average Nspt in Zi is about 25.
An example:
q = 200 Kpa,
Nave = 23
B = 2 m
Sc = 2.36 mm = 0.236 cm,
I found it very very low. I think it should be somewhere between 1 and 2 cms.
Please let me know If I have any mistake.
please find the original B&B graph with the Ic = f(NSPT) value plotted inside a spreadsheet file
the value would be Ic = 1.81
If you adjust the units (m to cm end so on) you might come up with a reasonable value for the settlement.
May be you want to take a look at the berardi's slide presentation I'm attaching, page 31/55, in the same presentation he also illustrates the Berardi and Lancellotta method
I took the oppotunity to review the method, with your foundation data the settlement, according to foundation depth and lenght (i assumed D=1 m, L = 10 m)
should be in the region of 8 mm + 4 creep settlement = 12 mm =about 1.5 cm
Many times the choice of the correct transformation law (i.e: NSPT to elastic modulus)is vital (and approximate), much more so than the choice of the algorithm itself.
From this point of view B&B tends to eliminate a source of error, the transformation itself, since it relates directly the settlement to the NSPT, withouth further passages, that would mean less additional error into the output.
Although the method has many shortcomings, it is the standard for Britain and other countries...
Sorry for the late response.
You said you got about 1.5 cm of settlement, did you use B&B´s approach or any other?. You assumed D = 1 m, L = 10 m. Wouldn´t a 10 m long footing be too much? (it is more a mat than a footing).
In my case, B = 2m and Depth of influence Zi = 1.7 m (2^1.7).
Still using you Ic value (1.81) I continue getting low settlement results.
Again,
Using B&B´s approach:
q = 200 Kpa,
Nave = 25
B = 2 m
Sc = B^075 * ((1.7/(NSPT^1.4)) * q
Sc = (2^0.75) * ((1.7/(25^1.4)) * 200 = 6.31 mm
Please let me know if I am using a wrong value,
Sorry for the inconvience.
