synchronization of hydraulic rams with flow divider
I hooked up the flow divider 1 line in 2 lines out to synchronize 2 rams. When I push the control block, the rams won't move & act like they are fighting each other. We changed the flow dividers, the control box, the pumps, everything I can think of with no new results. This is a very simple system and use the same type system on another machine & it works great. Any ideas as to what the problem is and what I should do next?
RE: synchronization of hydraulic rams with flow divider
Something is different.
Show us the schematic of the system.
Ted
What type of flow divider is it?
Spool or rotary gear type?
Adrian
