Rewritting MATLAB code to C code
Hello people,
Just a simple question, how difficult is it to translate MATLAB code to C code?
Thank you very much for your help,
Eduardo
RE: Rewritting MATLAB code to C code
Do not believe there is such a compiler, but Simulink might have some capabilities which I do not know. If anyone could clarify it would be greatful!
Thank you,
Eduardo
Thank you very much IRstuff. I will have a look at it! The point is that I am absolutely new to MATLAB, and really didn't know where to start from.
Eduardo
just rewrite the code to C smile
peace
Fe
Thank you for your help folks,
Eduardo
The Matlab "compiler" is a myth.  In the olden days, rubbish loopy Matlab code could be made to run faster by converting it into a MEX file and compiling it: the original Matlab "compiler".  This product has since morphed into a mere deployment tool.  It allows Matlab routines to run sans licence, so long as you don't mind the hefty baggage that's required.  m-files run more slowly after being "compiled" now.
For quick Matlab-ish code, write some C++ Matrix classes and pass off data to lapack/blas.
- Steve
