STEP file batch conversion
I am doing batch conversions from prt to step files in NX5, but whenever it converts an assembly with more than one level, it only converts the first level and discards all lower levels. Does anyone know how this can be fixed?
Thanks.
Thanks.
RE: STEP file batch conversion
Ben Loosli
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
If they're not working then what are they set to?
If it is looking for a load options file. Don't! at least for the moment. Test it another more manual way and see if it works.
Best Regards
Hudson
www.jamb.com.au
Thanks.
I suspect there could be two parts to your problem one is that the search paths aren't being set or followed correctly and the second is that whatever load options file you're using or think you're using isn't being picked up by the translator. So if you manually set the load options for a test then you'll have established what does work and be able to move a stage closer to finding what doesn't.
When it comes to setting load options for translations then As Saved may be your best default setting. Set the load options to that in testing as a way to
If you want to look into or show us a file that I think might be of greater relevance then it would be it will be the step settings file usually called ugstep214.def
Best Regards
Hudson
www.jamb.com.au
