HEC-HMS Deletes Data Table
I'm working on a very simple HEC-HMS model consisting of one drainage area, and one detention pond with a culvert as the primary outlet, and the dam top as the auxillary outlet. This model works fine.
The problem comes when I copied this model to test a condition when the primary outlet would be blocked and therefore ineffective. The only modifications I made were that I deleted the culvert, and switched the dam top to the primary outlet with an elevation primary condition rather than inflow=outflow. What's happening is that HEC-HMS deletes the elevation-area table that I entered for the detention basin. I re-enter the data, click "Apply" or "Save" and it deletes all of the data I've just entered. I know this normally means that there's something off somewhere else, but I haven't been able to find the problem.
Any recommedations on how to correct this?
Thanks in advance!
Thanks in advance!
RE: HEC-HMS Deletes Data Table
Froude: That's exactly what I ended up doing - just building a new model since it's fairly small. That did the trick, so thank you!
I'm still curious as to why a copied model would just delete the paired data set, and not allow me to create a new one. Very strange...
