Use of Intumescent (Fire Resistant) Paint on Pressure Vessels
Is the use of intumescent (fire resistant) paint an acceptable method of reducing the heat input into a vessel or tank from an external pool fire?
If so, how is the heat input calculated?
I know this type of paint has been used on steel structures, but we are being asked to use it on pressure vessels to reduce the heat input. I have doubts if this is acceptable, but would like to hear opinions from others.
Thank you.
Thank you.
RE: Use of Intumescent (Fire Resistant) Paint on Pressure Vessels
Good luck,
Latexman
It depends if they are looking at all the factors in your equation, as Latexman noted.
Nullfire is a well known supplier of these products http://www.nullifire.com Ive never seen a pressure vessel painted for fire protection, more often than not these are protected with flexible fire protection http
Ciao,
Itascot
