Sketch question
Sketch question
Can i copy curves or the lines of a sketch from one part to an other?
Best regards,
Michäël.
NX4.0.4.2 MP10 / TCE 9.1.3.8_build_0711 / NX6.0.2.8 / NX7.0.0.9
Belgium
RE: Sketch question
Mayebye there are other solutions?
Best regards,
Michäël.
Belgium
RE: Sketch question
Based on what you described above, if you had been using NX 7.5 you would NOT have had to then project or add the Pasted curves into your new or existing Sketch, you could have either created a new Sketch automatically or added those curves directly into an existing Sketch.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
RE: Sketch question
that sounds wonderfull, but we will switch to NX6 and not NX7.5, so i will not be able to use this new functionality for about 2 or 3 years when we will switch to a newer version.
But i'm happy enough with the way i did this right now, because our designers in the past often used curves to create models, but as i'm working on parts i try to convert them to sketches.
Off topic, I asked a question about TC unified a while ago on the forum, and you suggested to contact our Siemens rep. But we managed to solve the problem ourself ; the server Oracle and TC was on had the 3GB switch set in the boot.ini file which is not neccessary on a server, but apperantly it slowed the preformance down like hell. Removing the 3GB switch out of the boot file solved the problem, all the appl. on the server got a preformance boost.
Hasta luego.
Best regards,
Michäël.
Belgium
RE: Sketch question
That doesn't sound like the Flemish my grandfather spoke
John R. Baker, P.E.
Industry Sector
Cypress, CA
RE: Sketch question
