Rib - drafting
Rib - drafting
Hello, I want to create a drawing from a part with some ribs. I have a section and I don't want to cut the ribs. Is this possible? Thanks
RE: Rib - drafting
Make cutting lines for plane with 90 deg to avoid ribs or right click on a drawing view and " set drawing view depth "
Hope something is usefull
RE: Rib - drafting
You can do it by removing the hatching from the view, adding a line by drawing in view and then manually hatching.
Other than that most people just live with it being not to standards.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
RE: Rib - drafting
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
