NX4 Sketcher Question
Hi, I'm new to UG NX4. I have a question on how to make dimensions equal to another all ready created. When I used Inventor I could simply tag another dimension.
The only way I have found way use "expressions" on type in the P"xx". Is there an easier way.
Kyle
RE: NX4 Sketcher Question
All you have to do is double-click the Sketch Dimension you wish to set equal to another Dimension, select the small blue downward-pointing arrow at the end of the parameter widget, select the 'Reference' option, select the dimension that you wish this dimension be set equal to, and hit the OK button.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Thanks John, appreciate the reply. Have a great day.
Kyle
