Linear Elements Linear response FEA
Are Linear Elements and Linear response related?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Linear Elements Linear response FEA
The response of a structure from a first order analysis is linear in that if you double the load the deflection doubles for example.
Linear elements may refer to beam elements in the software unlike plate elements. Also it could be referring to the shape functions of the elements. For example a 4 node element instead of a 9 node that has 2nd order shape functions.
