20CrMnTi versus 20CrNiMo
Working on an application for a CV axle. Material called out for the cage in the supplier print in the CV joint is 20CrMnTi. This material was said to be equal to SAE 8620. I believe SAE 8620 is equal to 20CrNiMo. The part is to be carburized to HRC 58-62. This is an aftermarket application where increased strength and toughness over OEM is the goal. I believe 8620 would have a higher core toughness than the specified 20CrMnTi because of the Ni and would handle impact loads better. I understand that 20CrMnTi is frequently used for OEM CV Joint race and cages. My question is would 20CrNiMo be stronger or tougher than 20CrMnTi with the same heat treat. I do not have access to spec sheets on either material. Thanks for any feedback in advance.
RE: 20CrMnTi versus 20CrNiMo
