family table & pro/program
Hi all!  Need your assistance on this one.  I have search this forum and other with no luck.
I've got a family table with about 200 instance which may increase with time.   What I've got is a lookup_inst to see if that size part exist in the family table.  If it does than it suppress the 2nd part.   If does not,  I want it to suppress the generic part (with the family table) and use a 2nd part (which does not have a family table).  How do I go about doing this?  Thank You for any input.
INPUT
 SHAFT_OD NUMBER
END INPUT
RELATIONS
TEST_RUBBER = LOOKUP_INST ("MOULD_RUB_SILICONE.PRT", 0, "D0", SHAFT_OD, \
"D1", 0.250)
END RELATIONS
 ADD PART (TEST_RUBBER)
 INTERNAL COMPONENT ID 39
 END ADD
 ADD PART DRIVE_ELASTOMER
 INTERNAL COMPONENT ID 40
 END ADD
RE: family table & pro/program
Try the following:-
INPUT
 SHAFT_OD NUMBER
END INPUT
RELATIONS
 TEST_RUBBER = LOOKUP_INST ("MOULD_RUB_SILICONE.PRT", 0, "D0", SHAFT_OD, \"D1", 0.250
END RELATIONS
IF TEST_RUBBER <> "MOULD_RUB_SILICONE.PRT"
 END ADD
ELSE
 END ADD
END IF
Thanks for trying but it didn't work.  It suppress the 2nd part regardless and it still gives me the generic part from the family table.  Any other idea?
