Hardness testers
Hardness testers
I run a QA lab and we have an old Wallace Microhardness (IRHD) tester. It is hand operated and at least 20years old. I would like to replace it and wondered if anyone can suggest the best (or most commonly used) meter.
Are there any disadvantages/limitations with newer machines
Elastomatt
Elastomatt
RE: Hardness testers
See http://w
Tom Jablonowski, TSE Industries, Inc.
www.tse-industries.com
Cheers
Corrosionman.
Thanks for the info. we do use Shore A meters as well, some are handheld and I don't like them as the results seem variable (control of force).
Most of our customers now have more modern equipment and there have been some differences between our test results recently. I have had our machine checked out (by our materials lab manager) using the calibration pieces it was OK.
I will give Wallace a call and see what they have to offer, they do our annual calibration already.
Elastomatt
However we do check directly on product which have varying profiles, what is the maximum size dead load bench-mounted testers can take? And is there anything to be aware of (i.e. curved surfaces against flat)?
Elastomatt
You can always ply up 3 or 4 piecces of your sheet/part/whatever and use this for testing the hardness (but the result won't be quite as accurate).
