NX6 threaded hole edit
When I remove a surface that a threaded hole command has been added to I get an error that says.
"Unable to reference parent objects that are either suppressed or modeled away"
I have reattached the sketch and changed to along a vector instead of normal to face.
What is the best way to edit this command after the referenced surface is removed?
Thank you
Mike Aylward
Thank you
Mike Aylward
RE: NX6 threaded hole edit
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
John R. Baker, P.E.
Industry Sector
Cypress, CA
