Feature Control Frame
NX 6.0.5.3
I guess it's still not possible to create a Feature Control Frame with a Leader type of Flag on the end face of a cylinder ?
I did try resorting to my NX3 method of using the Simplify Curves option in an expanded view, but without success.
Any suggestions ?
Any suggestions ?
Specialty Engineered Automation (SEA)
http://www.sea4ug.com
a Siemens PLM Solutions Partner
RE: Feature Control Frame
That's what I'm using, but I can't select the end face of a cylinder, as it's an arc,
You can point to it as if it a note, but that may not be your preferred way.
If you have a hidden straight surface, such as on a keyway you can utilize that.
Go in view dependent editing, and make that straight edge something other than hidden and dimension to that.
