Difference Between ASME & ANSI Y14.5
Hi Everyone,
  What's the Difference Between ASME & ANSI Y14.5?  Also, are there any major differences with Y14.5-2009?
Jason M.
Unigraphics NX & SolidWorks Designer
RE: Difference Between ASME & ANSI Y14.5
forum1103: Drafting Standards, GD&T & Tolerance Analysis has had several threads about changes to the 2009 edition.
As to ANSI V ASME, this again comes up over in the Drafting Standards forum.
Essentially it used to be an ANSI document, I think 1982 was the last ANSI version.  At the 94 edition it became an ASME spec.
There are significant differences between 82 & 94 versions.  94 version has something like 7 pages explaining the differences.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
