TRANSMITTING FORCES
TRANSMITTING FORCES
i have a point where load is applied and i have to transmit it to two surfaces: front and rear surface
however, the front surface takes loading along the three axis (x, y, z) whereas the rear surface takes loading in one direction (x)
how can i do it?
how can i do it?
RE: TRANSMITTING FORCES
When you say point, do you mean concertrated point? How is it loaded in reality? Can you include a rigid body in the model and use this to transmit the loads?
when i say point, i mean a concentrated point...and loading is applied along the three directions..
However, the loading should be transmitted from this point to front and rear arms of a body...
And each arm takes a different component
the rear arms take only axial loading
the forward take loading along 3 directions
thank you
