Updating a Hole Dimension Table ?
I have a part drawing that contains many holes that are dimensioned using the hole dimension table.
Holes were added to this part.  So is there a way to update the table without having to manually update each item in the table?
RE: Updating a Hole Dimension Table ?
No, there isn't any way to update the table.
This is really something I think that should've been fixed by now.
As a policy, when we can absolutely avoid it, we don't use the tables because not only of this, but if the locations of the holes change the table does not update.
It's probably faster to delete the old table and make a new one
