FLITCH BEAMS - STEEL ON OUTSIDE OF LUMBER
I am reviewing a situation where flitch beams are needed, but there are already (2) 2 x 12's in place.
Can steel plates be added to lumber forming a flitch plate with the lumber in the middle?
RE: FLITCH BEAMS - STEEL ON OUTSIDE OF LUMBER
Buckling of the plate between the bolts will be more critical as it is not sandwiched between the timber beams, as is usually the case.
Can you add additional timber outside the steel plates?  That would control buckling.
Jim
Jim Kinney
Kennedy Space Center, FL
Don't know why not...
Mike McCann
MMC Engineering
Motto:  KISS
Motivation:  Don't ask
