better throughput using amplifiers
Hi everybody
I found an antenna (cisco ANT24120) which gives 2Mbps at 25 kilometers. Do you know how much I can extent the throughput by using an amplifier with this antenna? Do you know any compatible amplifier?
Best wishes
RE: better throughput using amplifiers
If it's a two way system (transmit and receive), you can't add an amplifier, it'll block the receiving info.
You can add a reflector behind that antenna to increase gain and extend throughput in one direction if needed.
Cisco has a Technical assistance center. Best to ask them.
There are bespoke WiFi bi-directional (not that there's anything wrong with that) amplifiers.
See this link (for example):
http://www.l-com.com/productcenter.aspx?id=2018
"...bi-directional Wifi RF amplifier products for wireless LANs consist of a low-noise receive amplifier and a transmit power amplifier. These amplifiers offer significant improvement in operating range and performance and boost your Wifi signal. They are compatible with IEEE 802.11a/b/g/n spread spectrum wireless gear."
Another technical is to make sure you use a short RF cable and a long Ethernet cable (mount the hardware at or near the antenna). Or use a WiFi repeater or 'Bridge' at the antenna. Such basic RF-common-sense tricks might give you several dB essentially for free. I've heard about installation where the RF cable was 100-feet long... sigh...
