Select from List ... three dots delay: how to change
Is there a way to change the delay time before the "three dots" appear, which allow you to see a list of the entities you may select? (The same list one gets after right-clicking on an object and choosing "Select From List").
Thanks.
Thanks.
RE: Select from List ... three dots delay: how to change
Preferences -> Selection...
...and in the section of the dialog titled 'QuickPick' and toggle OFF the 'QuickPick on Delay' option.
Now you may ask: "If I turn them OFF, how will I ever be able to use QuickPick?"
That's easy, if you want the "three dots" to come up just hold DOWN MB1 for approaximately 1/2 second and they will appear and when you release MB1 you'll instantly be in QuickPick. This way you have complete 100% control of WHEN, and even IF, QuickPick is triggered.
Now if you don't want to do that, but actually make the delay longer before it comes-up AUTOMATICALLY in the same section of the Selection Preferences dialog you can change the length of the lag-time.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Thanks! Great tip.
capnhook
Proud Member of the Reality-Based Community..
Can this be done?
...are stored in the 'registry' which while it's not impossible to share registry settings, it's generally not recommended.
John R. Baker, P.E.
Industry Sector
Cypress, CA
