Tack Welding Structural Nuts
Can you tack weld structural nuts? A325 or A490
I am aware of the AISC note "Anchor bolt material that is quenched and tempered should not be welded or heated". But does this prohibit the tack welding? The heat applied is minimal and applied only to the nut. Does this actually impact the properties of the material?
Obviously this is due to an access problem. I have seen this done throughout my career. As you all know there are bolting conditions where there are no other options. Prior to erection, the nuts are tack welded to the inaccessible inner ply of the connection. The bolts are then inserted from the outside and "snug" tightened by turning the head.
IS THIS ALLOWED?
(technical references are appreciated)
IS THIS ALLOWED?
RE: Tack Welding Structural Nuts
As you suggest, I wouldn't expect small tack welds on A325 or A490 nuts to significantly affect the material properties of the nuts near the threads. The further the tack is away from the thread, the better, thus probably less affect on large sized nuts, than on small ones. And, maybe the tack weld shouldn't be at the center of the flats on the nut. Be sure there is good contact btwn. the plate and bearing surface of the nut before tacking. I've seen it done too, and didn't disallow it. But, I often wondered, given the Q&T material and a quick weld, and no preheat, how effective the weld was. And, if they weren't just causing a crack prone HAZ at the nut surface. Maybe use a softer filler metal, so the weld is more likely the weaker material. We do pre and post heat Q&T materials, within restricted limits, for normal welding, so I'll bet the real issue is excessive heating or the arc strike type stress raiser.
I have not read the AISC note on Q&T anchor bolt material, and welding or heating on them, but it doesn't surprise me. I wonder if it wouldn't be read to mean: any excess heating will likely change the Q&T and thus the mechanical properties; and welding is more likely than not to cause a stress raiser, notch effect, crack starter across the highly stressed rod.
I suspect you won't find any literature or testing specifically approving or rejecting tack welding of nuts; and that you may find a few inspectors who might not allow it. Maybe AISC , AWS or the RCSC would respond to this question.
I did ask AWS and I am waiting for a response. I will ask RCSC at out committee meeting in June. AISC said "it is done, but not recommended". I was hoping for a more conclusive answer. I like a why or why not kind of answer. I wonder if any research has been done.
http://www.FerrellEngineering.com
Even the nuts is a problem due, I believe, to sulphur content.
You could try to get weld nuts.
If the electrode happens to stick when first touched to the bolt or nut, the temperature of the whole assembly can rise rapidly. Further, most welders will "drag" or flare the electrode to prevent such sticking. Dragging creates an intermittent arc strike, prone to creating localized hardening, thus increasing the crack potential. Flaring the arc creates a high localized temperature and uncontrollable results on the heat treatment of the bolt or nut.
Further, AISC says don't do it...see the notes in Table 1-C of the AISC 9th edition (p.4-4) "Anchor bolt material that is quenched and tempered (heat treated) should not be welded or heated."
But think of where the "tack weld" is and where the strutural stress actually.
The tack weld is on top of the nut, at the accessible end (visible end) of the bolt (or rod) where that (unstrained) end of the bolt is sticking out of the nut. Further, the tack (heat-affected zone) is physically located downstream of the nut - that is, past the point where the rod or bolt has been stretched and is holding the load.
The tack only affects a small point (small area) on the outside of one 1/6 of the threads: the whole shaft thickness is not heat-affected, and the area that is deformed (melted + heat-affected-zone around the melted area) is a small part of the threaded area.
Since the threads being welded are not carrying load, the center of the threaded shaft at the tack is not carrying load, and the top of the nut being tacked is not carrying load, what is the threat?
The tack is to prevent the nut from coming unthreaded - a greater danger than the local-damage to the bolt threads outside of the load path.
In this case none of the bolt or threads are welded. A wide flange column will be erected against a concrete wall. The wall blocks access to the column web on the far side. At the column splice the erector would like to tack weld the nuts (before erection) to the inside of the column flange. The bolts will then be install from the outside.
In a bearing bolt connection, how much stress is actually in the nut? No tension, just shear in the bolt.
I have seen this done several times. But, this time approval is my responsibility. I was hoping to provide a more solid response than "in my engineering judgement..."
The welds are not intended to be structural or transfer any force. Beyond the resistance needed to provide a snug-tight fit of the connection material.
Another confession, is that I have personally done this tack welding, as a young fitter in a fab shop. (A little knowledge, and simple instructions) My instructions were to make sure there was enough tack to secure the nut (simple). The worst case is if the weld breaks before the bolt is tightened. What is the fix for a "less than snug tight bolt with no access to the nut"?
Mechanics of Solids and Metallurgy came later in my education and career.
racookpe1978...while I agree with you, the fact is that if a failure of some type occurred in the future, the fact that this was done will be an issue....it might not have anything to do with the failure, but will become a significant red herring if nothing else.
You struck my concern on the head. I DO NOT believe the tack welds will impact the design of the connection. But, it will become a "red herring" if something happens. Even if there is no failure in the nuts or bolts.
I am hoping to find a firm position from which to base my approval. (maybe this is my conservative nature)
But, I am leaning towards NOT APPROVED, based on lack of information on this specific condition.
(is that hypocritical based on my personal involvement with this procedure in the past)
You will probably still get Q&T bolts, but that should be O.K. The nuts are applied in the shop under some control as to spec., but the A325 or A490's are all they have on the job site, and you certainly don't want to start mixing bolts out there, or Ron can add another item to his liability list.
Unfortunately, he has the right thinking liability wise too, although I don't like the direction that issue it taking these days. As he does, I do a fair amount of forensic work, and I spend half my time debunking these kinds of dumb side issues. I suspect that's why connectegr brought the question up too.
There are thin gage stl. locking/holding devices that get tacked to the stl. pl. over the bolt holes, positioned like a washer. They have two or three ears on them which are bent up the flats of the nut and slightly over the top, to hold the nut in place.
I do think this should be addressed specifically by RCSC or AISC. The fact is, this does happen in structural steel fabrication/erection often. And in most cases nobody asks for the connection engineer or the EOR's approval. On the structural drawings these erection issues are not always clear. So they get address on the fly, as the erection schedule pushes the decision along.
I plan to bring it up at the RCSC Committee meeting this summer.
ron & dhengr
concerning the hole diameter and substituting A307 nuts. The holes are standard for bearing bolts. Pre-tension for slip-critical connection and oversized holes would create a bigger problem and more questions. Combining A325 bolts with A307 nuts, is another of the issues that lack supporting information.
Thanks for all the responses and feedback.
WELDABLE NUT HOLDING DEVICE!!!
More, more, more information please...
Great solution, but I have never heard of this.
Maybe we need to patent our own version. Similar to a structural washer with wings to hold the nut.
Thanks for the help. I will let you know when the money starts rolling in.
If you want to accomplish the same thing, and assuming you don't have a bezillion of these to do, buy a sacrificial socket of the size to fit the nut....insert the nut in the socket, using a foam spacer if the nut is shallower than the socket. Weld the socket to the beam...now the nut is captive in the socket and will not turn when the bolt is placed and tightened.
You could design a variety of retaining devices for the nut based on similar applications for smaller nuts.
Tack weld one leg to the base metal, bend the second leg up and then tack it to the nut.
ALWAYS torque the nut and bolt before tack welding: Don't use the tack weld to hot the nut against turning when you are torquing the bolt.
In this case, you have no risk of the load trying to pass through the weld -- an extraordinarily bad idea as stated in other posts above. As long as you make the "nut" deep enough (and prove it), it shouldn't need to be much thicker than a normally-sized nut.
Engineering is not the science behind building. It is the science behind not building.
You might weld a nut to a washer, and the washer to the base, giving the system enough movement.
ASTM A563 covers structural nuts, not A325 or A490. There are 8 grades of nuts under A563, and some may be weldable. Be aware that the weld will be creating a stress riser in the nut, particularly if the connection is susceptible to fatigue cycling.
This is a practice that occurs. However, I cannot document an acceptable procedure. I agree that the weld must crack for proper bearing to occur. But will the crack occur in the weld or the HAZ of the nut? I am also aware that there are other structural bolts, such as A307, which are weldable. But, RCSC does not allow combination of bolts and nuts.
There are more problems than solutions. But as I said this procedure is used by fabricators and erectors, when no other solution can be found.
I have also realized another problem. If the welds must crack to achieve bearing, how does the designer explain the "bolt banging" when the building is in service.
Thanks for all the responses. I plan to follow up after the RCSC meeting in June.
If you do weld the nut, I suggest you put a bolt in it and pull it up tight before you weld, take out any space due to high spots.
I was told not to tack high strength nuts by a couple of level threes, they told me that some Q&T nuts cracked open at weld time and some later when the bolt was tightened. Even a tack weld heats and softens the material, it tries to expand but can't because it now has a lower E than the rest of the nut, so it is compressed. When it cools it tries to shrink, causing some considerable moments and forces in the nut.
It is as though you took a steel ring removed a piece and then glued the ends together.
Michael.
Timing has a lot to do with the outcome of a rain dance.
Michael.
Ferritic fasteners generally have higher carbon content than weldable structural steels, as well some have alloy addition. This is a recipe for cold cracking.
ASTM ?????
Think of it from the liability point of view. In case of an incident the standard or code essentially becomes law, and in this case the AISC clearly prohibits welding.
Now the technical aspect: a small weld is insignificant in size but constitutes worst-case conditions for hydrogen (or cold) cracking. Non-welding engineers and some welders with ignorance of hardenability concepts think they 'can get away with this'; these are the same folks who also wouldn't think it necessary to preheat, another no-no. But it does often get done by impromptu self-certified engineers in the field without benefit of even the back of a napkin to do calculations on.
If you must tack, use a nut of weldable material (provided it can handle the stresses). In general, preload and friction and not gimmicks are what keep a nut tight.
