my view boundaries come in too big!
If we can't resize the view boundaries (anyone know how?) Then what are we suppose to do with the big giant boundaries that always come in my drawings? They get all tangled up with each other.
Thanks!
Thanks!
RE: my view boundaries come in too big!
I will only work on primary views.
Ed
I'm only speculating here that this is happening in assembly drawings and not part drawings. If that is so then the large view boundaries could be caused by parts in the assembly that are hidden and not close to the center of the assembly. If that is the case then try suppressing these hidden parts and the view boundary should be much more reasonable.
- - -Updraft
Using the Autosize option helps reduce those.
Chris
SolidWorks 09 SP4.1
ctopher's home
SolidWorks Legion
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2009 SP 4.1
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
You need to remember to double-click in the view you want to add the sketch/annotation. It's a PITA if you forget to, I know.
Chris
SolidWorks 09 SP4.1
ctopher's home
SolidWorks Legion
Mechanical Designer
Fixed as in does not enlarge for some obscure reason? ... It hasn't happened to me yet, but the OP hasn't stated which version they are having trouble with, nor the reason.
