Problems with Convert Entities and Intersection Curve
When using Convert Entities and Intersection Curve in sketch mode, I am experiencing hangs, lock-ups or crashes. Anyone else? Time for a repair, maybe?
Didn't see anything directly related in the SW KB.
SW2010-SP2.0
XP Pro SP3
P4-3.2GHz
3GB RAM
Quadro FX500/600
SW2010-SP2.0
XP Pro SP3
P4-3.2GHz
3GB RAM
Quadro FX500/600
RE: Problems with Convert Entities and Intersection Curve
Jeff Mowry
www.industrialdesignhaus.com
A people governed by fear cannot value freedom.
Dan
www.eltronresearch.com
Dan's Blog
Suggestion from the SW forums was to delete all .NET framework installs and re-install only latest version, so am trying that. Will let you know if that fixes the problem.
