Multivariable algebrain equations
I'm trying to do Castigliano's theorem in Mathcad. Integrating in Mathcad is pretty easy, but is there a way to implicitly define functions?
For example, I would like to be able to enter
-M + F*0.026m + Q*0.036m = 0
(which is a force balance on a free body diagram)
and let Mathcad turn the above expression into
M = F*0.026m + Q*0.036m
so that it's an explicit expression for M, a moment term.
Is this possible? Or do I have to write out the steps manually?
RE: Multivariable algebrain equations
shimo,
1) Write out your original expression, using the Ctrl= (the bold equal sign).
2) Highlight the variable you are interested in solving for.
3) Select  Symbolics -> Variable -> Solve
4) Mathcad will display the solution.  You will have to provide the "M :=" at the beginning of it.
Good luck
Pete
Awesome, thanks.
But is it possible to make Mathcad define the separated variable M as the explicit function? I'd like Mathcad to output something like
M(Q) = F*0.026m + Q*0.036m
where F is a constant.
Doing it by hand is like 1 extra line, but it would look a lot cleaner if I could do it automatically.
Also, what's the function of the Boolean equal sign here? I don't understand how to use them.
Thank you! That Mathcad file really helped a lot.
excognito,
Great solution - I was not familiar with live symbolics 'til you showed it in your worksheet.
Pete
Yes, live symbolics are very useful.  However, you have to be aware that symbolics don't pay any attention to units (treated as variables - however, this can useful in certain circumstances), don't fully mirror the functionality of the numerics (eg, rand) and run noticeably slower than numeric calculations in general.
