3D array generated by for-command error
I have a set of input data which contains internal forces of number of beams together. I created a code which sorts these data automaticly. I think I wrote it correctly, but it seems mathcad does not agree...
The first piece of code identified that there are 4 beams and for each of them there are written 96, 160, 128, 64 rows respectively - THIS IS OK.
The second piece of code is extension of the first one. Each row contains 6 values, so I expect submatrices [6,96],
[6,160], [6,128], [6,64]. But I obtain [6,96],
[6,160], [6,160], [6,160] !!!
I think that code is correct what means that there is some bug in mathcad.
RE: 3D array generated by for-command error
Have a look at the attached worksheet I think the program loop looks a lot neater.
I can't understand why you want your answers separated by a comma!!!!!!
Mike
