tank internal coating material.
What tank internal coating material would you recommend if tank operating temperature is higher than 100 C. This is waste water tank with high chloride content.
Thanks.
RE: tank internal coating material.
One that has both a satisfactory qualification test report (preferably independent from the coating manufacturer)and a verifiable track record.  A mixture of NORSOK M-501 and NACE TM0174 would make a good qualification test regime.
Steve Jones
http://www.oilandgaspeople.com/cv/11499664
http://www.linkedin.com/pub/8/83b/b04
Thanks.
Dear Johnae
I agree with Steve Jones.
Note that short and long term coating behaviour in severe conditions can be simulated and analyzed using CheFEM (Chemical interaction driven FEM analysis of advanced materials). This will allow more systematic and completely independent evualuation of polymer based coating materials (including eventual required reinforcements).
Kind Regards,
Rodney
http://www.composite-agency.com/CheFEM.htm
