AISC Table 6-1
AISC Table 6-1
Folks,
I need some clarification regarding Table 6-1 and Chapter H of AISC 13th edition.
Example: W14x90 column that is subject to axial load and biaxial moment. The column is unbraced 14' in the major axis and is braced at mid-height on the weak axis.
Kly = 7'
KLy,equiv = KLx/ (rx/ry) = 14/1.66 =8.437 [Controls]
Pc = 1125.6 kips
For W14x90 Unbraced length Lb for beam = 14', bx = 1.55 and by = 3.26
I want to make sure that "p" is calculated based on larger of (KLy) or (KLy,eq)=8.834' which would be (0.8872) and not 0.976 based on 14'.
Kly = 7'
Pc = 1125.6 kips
RE: AISC Table 6-1
RE: AISC Table 6-1
