pressure vessel unfold sheet metal
I need a add- on program that will run with solidworks that will allow me to make ASME Pressure Vessels tanks..
I want to be able to unfold the the tank to its flat pattern.
the middle section is easy its the top and bottom that I cant do
I've been told by support that the regular sheet metal package wont work Solidworks
RE: pressure vessel unfold sheet metal
The standard sheetmetal package is only capable of generating flats for linear bends.  For more complex forming my understanding is blankworks can perform those operations:
http://www.forming.com/SW.htm
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
You can also use LogoPress3 http://www.logopress3.com/en/index.php
A bit more cost effective then BlankWorks as you can buy just the flattening modules.
You can also search the SolidWorks Gold Partners.  Select Sheet Metal in the first drop-down.
http://www.solidworks.com/sw/products/engineering-software-partners.htm
Cheers,
Anna Wood
Core i7 EE965, FirePro V8700, 12 Gb RAM, OCZ Vertex 120 Gb SSD, Dell 3008WFP 30" Monitor
SW2010 SP2.1, Windows 7 x64
http://www.solidmuse.com
http://www.phxswug.com
