Anchor Reaction Block Design
We are designing permanent post-tensioned anchors into shale to stabilize a 3H:1V cut slope. The anchors will be inclined 30 degrees from horizontal. The reaction blocks will bear against soft clay shale, very stiff clay, or alluvial sand. I have tried analyzing the blocks using passive pressure against a battered retaining wall with a sloping backfill and also as footings, using bearing capacity formulas. I am not really comfortable with either model. How do others approach this?
RE: Anchor Reaction Block Design
If you can think that for sure you will have a toe failure, it is still a case to be considered in the overall slope stability study. Furthermore, the formulas of bearing capacity usually are derived for symmetrical long-wall footings, and the bearing of these walls or blocs is unsymmetrical in that one side has far less overburden than the other.
In all this means that I see more prospective success for analysis in the slope stability hypoyhesis, assuming logarithmic spirals or the locus of maximum shear stresses revealed by 2D plane strain analysis for the soil.
I designed anchor blocks for one of these landslide walls for a PENNDOT job. Call me.
www.PeirceEngineering.com
