Cylindrical dimension margin
In the "cylindrical" dimension there is the option of using a margin (the center of the cylinder) as one of the entities, and displaying the dimension as the full diameter.
Can I assign something else, other than the center of the cylinder, as the margin?
Is there a way to use a margin, such as this, on a horizontal dimension?
I have a large radius, where the center is off the drawing, that I need to dimension to - and using a margin would make it look cleaner.
I am on NX6
I am on NX6
RE: Cylindrical dimension margin
For a good overview of Cylindrical dimensions and how you can use the Baseline option in various situations may I suggest that you open the User Documentation and do a search on 'Cylindrical Overview'.
The only other thing that is similar is creating a Folded Radius dimension where you can define the radius arrow coming from a point other than the center of the arc/circle being dimensioned. This is useful when only a segment of arc/circle is in a view and center is offscreen or would extend into and thus interfer with another view on the Drawing.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
I did read the "cyindrical dimension" doc and it was very helpful.
