Construction Joints and Control Joints - Spacing Limits
I have always seen 30'-0" limit to the spacing of construction joints for exposed walls and 60'-0" limit for unexposed walls. Why is this? Is this referenced somewhere in ACI? Can these limits be increase if you are using the minimum temp. & shrinkage reinforcing? What if you cut every other bar at the construction joint? Can you use crack control joints in place of construction joints and pour longer lengths?
Thank you!!
Thank you!!
RE: Construction Joints and Control Joints - Spacing Limits
To answer your other questions, all those things contribute to good crack control, but you're better be 100% confident before you exceed customary guidelines. Because if there's a problem, some engineer will be glad to testify that you violated these guidelines.
That being said, I've went to 40 ft and beyond many times. We use .005 temperature and shrinkage steel.
An expert is a man who has made all the mistakes which can be made in a very narrow field
The .005 reinforcing ratio (we top out at .0052) is actually from ACI 350, the code for Environmental Concrete Structures. So it would apply for water retaining walls. It's a requirement for temperature and shrinkage reinforcing based on movement joint spacing. And since we always violate the spacing of movement joints (40') we always use the .0052 ratio.
