Swept Blend Issues
Swept Blend Issues
Swept Blend Issues
Hi Im trying to create a swept blend with 5 sections in total, 4 of which are on parallel datums with the central one on an angled datum.
However, Pro/E will only let me use the first two sections and I can't see why I'm unable to use any of the remaining ones? I CAN select them, but it just says that the feature cannot regenerate when I do so.
HELP ME PLEASE!!
RE: Swept Blend Issues
Im using Wildfire 4.0 btw
Can you upload the *.prt file so we can have a look, or even a screen image?
Have you made sure that all the start points are in the same place, it will try to twist the feature if they are not?
Adrian
never mind now, i forgot that i had split the edges of the last 3 sections so that they had more 'points' on them than the first two did, such a frustrating program at times!
