Perforated Metal Cladding - Partially Enclosed?
Actually, I have two questions.
The first is specifically the design fo the cladding itself. applying pur bending assumptions to the system results in extremely thick plates. I expect it to behave more like a net - in tension - but I'm uncertain of how to approach this via calculation.
The main question here, however, is whether the openness of a 15% open cladding could - placed on both side of a structure - would create a case for partially enclosed.
To be specific, it is a monoslope canopy spanning between two closed structures, with this 15% open metal cladding on each end. The Open metal is not attached to our structure (the canopy). One side has roughly 56% more opennings than the other.
On one side, I would think the wind would flow freely through the holes (1" to 1/2" in diameter) and build up in the interior of the structure with less area to escape.
on the other side I see the argument that wind will not flow freely thru the system (acting like a typical hurricane barrier), and therefore what ever does get inside will be low pressure and easily pass through the area at the other end. I beleive this to be the case, but I would rather have backup in the event that it is questioned.
Is anyone aware of any test data that may conclude such a case, one way or the other?
P.S. the difference in the resulting wind loadings for this case is a staggering 38PSF difference between ecnlosed vs partially enclosed... so the question is pretty important.
thank you
thank you
RE: Perforated Metal Cladding - Partially Enclosed?
