ASTM designation for this bolt
Anyone knows what's the ASTM designation for this type of bolt? A client is using them on their equipment and I was asked to check the allowable load values.
http://www.mcmaster.com/#92196a712/=6h3l8k
A link to the ASTM specs would be much appreciated.
RE: ASTM designation for this bolt
Specifications Met: Not Rated
And they're not even willing to say that they're any specific ANSI grade of stainless, just "18-8".
If whatever these are holding on is important enough to ask you to check the allowables then it's probably important enough to use identifiable fasteners.
The noted spec. is available from the usual sources, and shouldn't cost more than about $35 in downloadable pdf format.
