Heat input in wedling pipelines
Anyone knows what shell be the maximum heat input that can be produced in welding fittings to pipelines under pressure (natural gas flowing in the pipeline)? I have the Welding procedure records for those welding productions, where I can calculate the heat inputs based on the I, V and welding speed, but those aren´t the values for wich we shell base on because the conditions during welding are different from those that there were in the qualification.
RE: Heat input in wedling pipelines
The maximum heat input is that qualified with the allowable tolerances and stated on the WPS!!
Steve Jones
http://www.oilandgaspeople.com/cv/11499664
http://www.linkedin.com/pub/8/83b/b04
You say the operating conditions of the pipeline are different than the values in the welding procedure? In what regards? (flow rate, carbon equivalency, wall thickness etc.)
