"Measure" function - Wildfire 4.0
Hi Guys,
I have just started using Wildfire 4.0. It was Wildfire 2.0 before this.
The problem I am having is with the measure function, as in " Analysis / measure ". I want to measure the distnce between two parallel surfaces on seperate parts. I find it very difficult to pick up a surface in a complex assembly. In 2.0 it was possible to choose surface beforehand, but this is not possible in 4.0.
Any tips on how to overcome this? banghead
RE: "Measure" function - Wildfire 4.0
In the bottom left of the Dashboard is a drop-down box, use it to select Surface - this will force you to only select surfaces
Cheers, robertib.
I found it.
I knew it had to be something simple.
Wonder why they changed it. I never actually used that dashdoard in W2.0.2thumbsup
