Shock Response Spectrum using ANSYS Workbench
Can anyone say if it's possible to analyze an object in ANSYS WB when the object is exposed to a Shock Response Spectrum? If not, is there a way to do it with command snippets from ANSYS Classic?
Bruce aka Tunalover
RE: Shock Response Spectrum using ANSYS Workbench
You can do this with the response spectrum analyse in Workbench.
Thanks for the reply.
In which revision of ANSYS WB is this available? I have Rev. 11.
Bruce aka Tunalover
I have Workbench Rev. 11 and that version does not have response spectra capability. Is there a way to use command snippets from ANSYS Classic?
Bruce aka Tunalover
