Gas and Liquid in pipe
Good Afternoon !
I would like to know when we flow gas and liquid (oil + water) in a pipem, what are the things which we have to be aware except drop pressure, line integrity?
Thank you
Thank you
RE: Gas and Liquid in pipe
"The problem isn't finding the solution, its trying to get to the real question." BigInch
http://virtualpipeline.spaces.live.com/
Does anyone have a software to do drop pressure calculation?
I tried to do it manually and the result are very strange. I used the example 17.4 done in "Fluid and Flow piping" Section 17
I found a drop pressure of 6900 Kpa which is strange cause the inlet pipe pressure is 650 Kpa. Maybe such calculation are fit for short line..cause I am working on 40 km pipe.
Thank you.
Hand calculation of the pressure drop in a multiphase pipeline (as opposed to mutiphase piping) isn't really very practical.
Flow regime will change many times per second and a correlation that works for wavy flow will not work for annular flow. The changes are random and happen on their own schedule. You can spend a bunch of money on OLGA or HYSIS or PipeSim or PipeFlo, etc. and you'll get numbers. You can then take those numbers to 9 decimal places and pretend they mean something--they don't.
It isn't hopeless, but you need to REALLY be certain about (1) what it is you are trying to do (will someone get hurt if you get it wrong?); and (2) what sort of reliability and repeatability do you expect. Typically you will have to lower you "accuracy" expectations dramatically.
David
www.korf.co.uk.
Steve Jones
http://www.oilandgaspeople.com/cv/11499664
http://www.linkedin.com/pub/8/83b/b04
I presume such sources to be abundantly available inside long process/petroleum pipelines&
especially if the gas and liquids are not controlled/ maintained 100% pure/clean
thus any contaminants could be finding their way into these main flow streams and erosion becomes inevitable in such heterogeneous flow conditions!
Moreover flow stream heterogeneousness also gives rise to static charges generation beyond/above usual consideration; possible creation of Ignition source(s) may result.
Best Regards
Qalander(Chem)
