eccentric cleats
eccentric cleats
RE: eccentric cleats
RE,
I just noticed your new signature line.  I like it, sounds better than some of the other things I have been called as an expert, e.g. "a has-been drip under pressure" and "a guy from out of town with a briefcase".
only a fool would call themselves an expert
Hokie,
The change signature line is due to having the week off work and found it a distraction from my task of updating all my spreadsheets to current design practices in the ASI.
An expert is a man who has made all the mistakes which can be made in a very narrow field
My version of an expert:
The well qualified practicing engineer knows a lot of things about a lot of different topics.
In time some of them begin to know more about less.
Then they become an expert and know almost everything about almost nothing.
RE: Could you post the title and author for the paper that you referred to above?  I'd like to get myself a copy.
KK as requested:
DESIGN MODEL FOR LIGHT BRACING CLEAT CONNECTIONS
T.J. HOGAN
Consultant to Australian Steel Institute
R. T. COLLINS
Engineering Systems Pty Limited
