Spacing between supports for no leakage through pressure plate
Hi All :
We are currently testing our blast doors to ensure there is no leakage.
Test is performed by closing the door and clamping a plate (with gasket) on the other side of the door frame.
Door
| | Door Frame
Test Plate
(Top View)
Once the set up is ready, air is filled into this closed chamber and is pressurized up until 11 psi.
I have to ensure that no air leakage occurs from the Test Plate Gasket seal. How do I select the spacing between clamps to ensure there is no leakage ?
Input is :
Length of Plate = 133.4in
Width of Plate = 123.5in
Pressure = 11psi
Gasket Thickness = 0.5in
Gasket Width = 2in
Kapil
Structural Engg., EWI
Door
| | Door Frame
Test Plate
(Top View)
Input is :
Pressure = 11psi
Gasket Width = 2in
Kapil
