Seated Connection Design
I am designing a seated connection plate to support a contunuous beam that will experience a large bending moments over the width of the support. Does anyone have any examples of the required checks for this type of support or provide any advice?
Cheers,
999
Cheers,
999
RE: Seated Connection Design
An expert is a man who has made all the mistakes which can be made in a very narrow field
rowing>> Did you just have a thread, on Pat's Pub, vaporized by the powers-that-be, about a week ago? You wondered (as I recall) if anyone had any ideas for improving the functioning and improving the interaction btwn. participants on any given thread. Since you and I don't manage or have any control over this forum, I assumed you were not talking about this forum, but I thought you had started a thread that could have benefitted all, and I was sorry to see it disappear so quickly.
Yes I did have a thread, and yes it was vaporized, however the ideas with-in were received by the powers. They seemed to take them on board.
I'm fairly new at this forum thing, although much less new at engineering, since I have been running my own consulting engineering firm since 1977; and 10 years before that I left Grad School and had two jobs in the interim. I find this forum, the whole gamut, quite interesting: many times enlightening because of the range of questions and of how others look at the same issues; sometimes frustrating for the poorly thought out questions and lack of info. which might lead to a meaningful discussion; many times fairly time consuming because I just don't have many quick answers (glib or quick & dirty) to complex problems. I think I could really enjoy picking a few young people here and mentoring them or working with them on a closer level, on their questions and problems. That would be far more meaningful to me than a hundred questions, all kinda quick and dirty, and then another question, and you never really hear about the final results or outcome.
Why are you trying to transfer the moment into the column? Can't the moments on each side of the column be balanced?
DaveAtkins
To transfer moment into the column you need to engage the flanges of the channel. A seated connection detailed the way you have it will not transfer moment into to the column.
When I first started out, I detailed seated connections because I felt it was a more positive bearing-type connections. For your design, I would detail 4-bolts thru the web of the channel fixing to the flange of the column and would not try transfer moment from the channel to the column.
