Ordinate dimensions in detail views
Is there a parameter that has to be activated to get the ordinate dimensions in the parent to show in the detail view?
Reference the What's New PDF page 81.
Christopher Zona - Product Designer
Loretto, Ontario
RE: Ordinate dimensions in detail views
You will need to delete the dimensions from the standard view that you want shown in the detail.
Then, Right-click on any of the ordinate dimensions in the standard view, select 'Add ordinate', click the point/line in the detail view that you want dimensioned.
It should add the dimension in the detail view, while still relative to the origin in the standard view.
Hope this helps.
