Engineering Changes--Class I vs. Class II Changes
Most companies employ change classes on their engineering change documents to indicate whether the changes are major (affecting form, fit, or function) or minor (eg, typos). My experience is that Class I indicates major changes and Class II, minor. However, I don't know of a reference that defines this common practice. I've checked MIL-STD-100 and ASME Y14.100, but I didn't see it defined in either. Is there such a reference?
RE: Engineering Changes--Class I vs. Class II Changes
The thing is, if the modified part/assy is no longer fully interchangeable with older revisions then per Y14.100-2004 6.8 & D-13 it should normally be a new part number.
So in essence a class 1 change as you've defined it means new part number chased up through the assy levels until interchangeability is restored.
Class II is a true drawing revision.
Maybe look in ASME Y14.35M-1997 but I don't see it.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
"Class I changes affect an item's fit, form or function. These are changes that affect an item's specifications, weight, interchangeability, interfacing, reliability, safety, schedule, cost, etc. Class II changes are changes to correct documentation or changes to hardware not otherwise defined as a Class I change."
Interchangeability has its own set of requirements as well. Where I currently work our documentation is a plagiarized version of MIL-I-8500D "Interchangeability and Replaceability of Component Parts for Aerospace Vehicles"
Mike
Thanks for your inputs...very helpful Mike, you're reference led me to MIL-STD-480, Sections 5.1 and 5.2, which define Class I and Class II changes...just what I was looking for.
Thanks again!
Chip
Mike
