Section View Label
Section View Label
In NX there is a setting to have the section view letters be a certain factor bigger than the default text size,
but the word SECTION is the default text size.
Is there a setting to have both the word SECTION and the section view letters be a factor bigger than the default text size?
I would much rather have it the way it is but the "higher-ups" want them the same size ... also, it is not a big deal to manually edit the label after it is put on the drawing, but it would be nice if we didn't have to.
I am on NX6
I am on NX6
RE: Section View Label
The '2' is a multiplier of the text size from the default size.
Ben Loosli
On your drawing is it before the word SECTION?
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
In drafting mode, select Preferences from the menu bar.
Then select View Label...
In the pop-up window, choose the Section button.
Change the Prefix from SECTION to <c2>SECTION<c>.
Ben Loosli
