Problem in 1500 KW DC Motor
Hello All
The attached pictures shows a problem happening in a 1500 KW DC Motor.
Any idea about the problem source? What to test?
Thanks for the Inputs
Carlos
Carlos
RE: Problem in 1500 KW DC Motor
Periodic cleaning - at least once a year - seems to be a good thing to do.
Gunnar Englund
www.gke.org
We can see a layer of something on the risers that is starting to flake and curl near the burned area. Whether that is a layer of paint or a layer of dirt, that close to the brushes it will have a high carbon content. It looks as if several more risers may flash over soon unless they are cleaned.
Bill
"Why not the best?"
Jimmy Carter
Muthu
www.edison.co.in
What test think can we do? maybe vibration? verify the cooling?
Thanks again
Carlos
Muthu
www.edison.co.in
So, the bare metal was due to welding? No arc there?
Gunnar Englund
www.gke.org
The arc you see is due to we repair the broken raisers.
Last Photo attached
Carlos
Muthu
www.edison.co.in
